Back to inductiveautomation.com
The Enterprise SCADA
Starter Package
Get Started with Ignition Enterprise SCADA for under $65K
Starter Enterprise Architecture
Create a secure, connected system that sends data from two independent local sites to a centralized corporate site. The Ignition Enterprise SCADA Starter package includes all the Ignition software you need to deploy this basic enterprise architecture.
PACKAGE DETAILS
Ideal Use Case: Multi-Site SCADA
This package is ideal for companies that have more than one site. Site A and Site B have fully functional SCADA servers that can act independently if the network drops between the sites. While the network is up, Sites A and B can send aggregate data to the Central Server, where overview dashboards and reports can be viewed in real time. Projects, data, and reporting can be synchronized across all servers. Additional functionality and sites can easily be added in the future.
What's Included in the Package
Central Site Ignition Gateway
- Ignition Platform
- Perspective Module
- EAM (Enterprise Administration Module) - Controller
- Industrial Historian Solution Suite
- Alarm Notification Module
- Reporting Module
Site A Ignition Gateway
- Ignition Platform
- EAM (Enterprise Administration Module) - Agent
Site B Ignition Gateway
- Ignition Platform
Ignition Perspective Module
With the Ignition Perspective Module, you can easily build mobile-responsive, pure-web industrial applications using HTML5 and instantly deploy an unlimited number of mobile clients through a web browser, the Ignition Perspective Mobile App, or run them natively on your device.
Package Product Descriptions
The Ignition Enterprise SCADA Package includes the platform and modules listed below.
Ignition Platform
The Ignition platform is the foundation for every Ignition system; it includes powerful features and core drivers to connect all your industrial data and devices.
Unlimited Tags
Use as many tags as you need for devices, databases, and anything else.
Unlimited Designer Clients
Get your whole team to develop projects, even at the same time.
Powerful Connectivity
Connect to any major PLC and database with built-in SQL database connectivity and the included OPC UA Server Module and core drivers.
Perspective Module
The visualization module for cutting-edge modern industrial applications. Quickly build full-featured industrial applications for monitoring and control, using the latest mobile-responsive, pure-web technology. Perspective applications are build-once, run-anywhere-compatible with three distinct deployment technologies that give you a wide range of options. Deploy directly to web-browsers for a modern, pure-web experience. Leverage the native mobile applications to gain access to hardware features such as the device’s accelerometer, Bluetooth connectivity, geolocation, barcode scanning, and more. Finally, leverage Perspective Workstation to add full kiosk mode and multi-monitor support, perfect for control rooms, touch panels, and HMIs. Perspective gives you total freedom to visualize and control your process however you want, on whatever device you want.
EAM (Enterprise Administrator Module)
The EAM provides a secure and intuitive way to manage many Ignition installations from one location. It is ideal for large enterprises that deploy multiple Gateways across vast geographical distances, but even companies with a few Ignition Gateways on a single plant floor can benefit from its ability to synchronize projects, monitor performance, and automate backup and recovery from a central location.
Utilize built-in data historians, easy connectivity to external SQL databases, open technology, and a library of tools to build a historian solution for nearly any application with the Industrial Historian Solution Suite.
Build an advanced alarming system that fits the needs of your operation with the Ignition Alarm Notification Module, SMS Notification Module, and the Voice Notification Module to send, receive and acknowledge alarm notifications via email, text message or a phone call.
Reporting Module
The Ignition Reporting Module is a standalone reporting solution that simplifies and enhances the reporting process from beginning to end. Generate reports from existing files or create them from scratch. Pull data from a variety of sources and design reports with a simple-to-use interface. Add charts, graphs, tables, crosstabs, shapes, and other components for visual impact. Save your reports in PDF, HTML, CSV, and RTF file formats, and set up automatic scheduling and delivery.
Total Package Pricing = $63,195
The Ignition Enterprise SCADA Package includes the modules and products listed below.
3 Ignition Platforms
$3,600
3 Perspective Modules
$33,675
3 EAM Modules
$4,785
3 Alarm Notification Modules
$6,735
$10,500
3 Industrial Historian Solution Suites
$3,900
1 Reporting Module
Get Started with Ignition SCADA for Enterprise
We know every company is different, so to get fast answers and friendly advice in a one-on-one conversation, just fill out the form below, and we can help you find the ideal Ignition system for your company today!
Some of the companies that depend on Ignition:
Inductive Automation • 90 Blue Ravine, Folsom CA, 95630 • 1-800-266-7798 (toll-free) • 1-916-456-1045 (int'l) • Email Us
